anima decorus
anima decorus
Visits: 10
Please add a Safe Zone option to be able to make the scene compatible with mobile phone videos (instagram, tik tok, etc.) where the aspect ratio is 9:16. Also an export to that aspect ratio as part of the drop-down menu during export. kind thanks
Last Active: 3 days ago
Posts: 5.7K,
Visits: 26.4K
Open an empty Project in iClone and select Render > Video. Select the video file format that you want to use and in the Output Size set the resolution that you need. Next navigate to Project > Custom in the Content Manager and save this project with a meaningful name to use as a template for future projects.
anima decorus
anima decorus
Visits: 10
Thank you for the reply, but I meant this for Cartoon Animator
kylelee
kylelee
Visits: 4.2K
anima decorus (6/29/2021) Thank you for the reply, but I meant this for Cartoon Animator
You can set the output size as 720*1280 then set it as the default project. In this way, the next time you open the Cartoon Animator will keep your settings ; height: 22px; width: 22px; top: 10px; left: 10px;"> 您可以將輸出大小設置為 720*1280,然後將其設置為默認項目。 這樣,下次打開 Cartoon Animator 時會保留您的設置
