Flatten and sample axis to clean motion capture files
Posted By fabio.alexandre.barletta 3 Years Ago
New Member (52 reputation)New Member (52 reputation)New Member (52 reputation)New Member (52 reputation)New Member (52 reputation)New Member (52 reputation)New Member (52 reputation)New Member (52 reputation)New Member (52 reputation)
Posts: 4, Visits: 95
When you use the sample in the motion clip for some part of the body, you can edit the key frames. But it would be great to be able to see the translation and rotation keys on the XYZ axes for each key frame in different time lines. Being able to clean up motion capture files faster. Or a smother option that helps remove shakes from files.
  Would be like this:
Right hand:
                       X rotation:
                       Y rotation:
                       Z rotation:
                      X translation:
                      Y translation:
                      Z Translation:
It is not a definitive solution, but it would help to delete key frames on axes that that shouldn't have keys
Last Active: 15 hours ago
Posts: 15.7K, Visits: 30.5K
It is an additional purchase, but the Curve Editor provides what you need, if I understand you correctly.
If you have separate XYZ keys in the timeline it would be hard to know which ones are superfluous. All data is expressed in world space, so if a character or something else is turned other axis values, than the obvious one may change as well.
In the Curve Editor you can really see what is going on, and it has an option to reduce the number of keys.
EDIT: I notice this is posted in the CC wish list, but this would really relate to iClone as CC doesn't deal directly with motions although it can export them.
3 Years Ago by animagic
That is great. I I din´t know. Thanks!
