I first discovered this after importing a DAZ character into iClone via Character Creator 3.
To narrow the 'variables', I tried to replicate the issue totally from inside iClone, using a stock Avatar and yes, I reproduced the problem.
However I have a gut feeling the visibility of the problem depends on lighting *angles* used.
So I proceeded as follows ...
● Loaded the 'Base Male' into iClone (default position and default pose)
● Using the 'existing' default lighting:
The 'Key light' was 'Multiplier' = '1' at the following angle:
Rotate X: -11.905
Rotate Y: 73.879
Rotate Z: -73.861
The 'Back Light' was 'Multiplier = '3.51' at the following angle:
Rotate X: -1.877
Rotate Y: 77.763
Rotate Z: 88.746The 'Side Light' was switched 'OFF'
The IBL used was 'Cayley Interior' at 'default orientation'. 'Strength' = 25 (no sRGB)
Iray 'preview' was then activated:
1. Default result with above lighting and 'Physically Accurate Cornea' = 'ON' (default)
2. 'Physically Accurate Cornea' is now turned 'OFF'
3. 'Physically Accurate Cornea' 'ON' and 'Smooth Mesh Subdivision' switched 'ON' (level 1) (Really wierd)
4. Physically Accurate Cornea' 'ON' and 'Smooth Mesh Subdivision' switched 'ON' (level 2)
5. Physically Accurate Cornea' 'ON' and 'Smooth Mesh Subdivision' switched 'ON' (level 1) KEY LIGHT switched 'OFF' (similar to #3 above - but 'fainter')
3 Years Ago by
sonic7
