Kelleytoons (4/25/2021)
Hal is too new a release for me to have (I wait a month as a rule) so if you have even a slightly older character I can try and see what's happening.
My only response now would be to make sure you are importing at 4K (since you're importing all the textures over).Hi Kelley, thank you for your answer, yes I had the issue with another character but I can't recall which one.. I'll check
I did find that the displacement map is causing the main lips issue
but when I remove it then the cuts on body are worse:
But, and hopefully a good "but"... I did not import at 4k but 2k. As it takes a long time to convert I'll try soon and see if it improves
edit: I'm stupid. when sending this message I realized that the cuts are worse because there is a displacement map on the rest of the body too.
I wonder what this does.. what do I lost by removing this height map
3 Years Ago by
Necka
