Visits: 60.6K
Of course I must confess that my chain is actually exactly the same method as the wallet chain! Just broken down into an efficient way to build it! Because it is actually just using the constraints to be "chain-like", the actual physics collision is not terribly important for its functioning. But external physics objects will push on it and make it deform properly. The constraint on the top link can target your lift vehicle. But you need to set the lift vehicle to have physics to target it. Set it to "Kinematic" (like I did with the top chain link) so you can animate it. The physics floor can be found in the "Create>Physics" menu.
jessicalcrichton
jessicalcrichton
Visits: 332
Okay, I got really far, but the top link's constraint won't accept the bottom of the blades as a target. Here's a screenshot: So you can see the block above it is the part I want to connect the constraint to, but when I try it doesn't do anything, and stays on "world". I'm going to keep trying things...
Last Active: 14 hours ago
Posts: 5.0K,
Visits: 15.9K
Activate Physics for blade first and make it kinematic (if the blade would be animated to drag something through the chain). Then pick it as P2P target.
3 Years Ago by
jessicalcrichton
jessicalcrichton
Visits: 332
Okay, I figured that one out. Aaaaand, it WORKS! Here's the little video I promised. I still have to make the chain and such look prettier, but that'll be easy. And of course I need to smooth the animation which I'll also do soon. THANK YOU ALL SO MUCH! You've helped me so much. <3
jessicalcrichton
jessicalcrichton
Visits: 332
Here is the final look I'm going for. One with no background and the other with the clouds that will be in the final video. One more issue I've run into, though, is that I can't attach the spiderbot to the character because there is no option to attach for him, and the spiderbot is already attached from the top top the chain. I tried link, but he fell off almost immediately. Any idea how to do that? Thank you all again. You've been AMAZING!
Last Active: 33 minutes ago
Posts: 15.7K,
Visits: 30.5K
jessicalcrichton (4/12/2021) Okay, I figured that one out. Aaaaand, it WORKS! Here's the little video I promised. I still have to make the chain and such look prettier, but that'll be easy. And of course I need to smooth the animation which I'll also do soon. THANK YOU ALL SO MUCH! You've helped me so much. <3
You need to set your video to Unlisted to make it visible to others with the link. It look like you have to set to Private.
jessicalcrichton
jessicalcrichton
Visits: 332
I did because I don’t want everyone to see it, since it’s unfinished and I’m debuting the video when it’s fully finished. I didn’t think about unlisted. LoL I’ll do that.
jessicalcrichton
jessicalcrichton
Visits: 332
Welp, it was great... up until I linked the character. At first, I linked him to the spiderbot, and this happened (both videos are by-frame): https://www.youtube.com/watch?v=CjUD7LBEPxYSo I thought maybe if I linked the chain to the character directly, it would be better, so I linked him to the chain via a long box on his back (so the chain wouldn't be too short), then attached the spiderbot to him. This happened: https://www.youtube.com/watch?v=7yRotUpciVoSooo... what am I doing horribly wrong? Eep! I've thought about animating the two parallel to each-other in order to give the illusion that they're attached, but that will be a lot of work. I'm willing, but before I try, is there a better way?
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
yeah, math! - I'll let them help on the physics some more because they've got great knowledge of the software and this is an opportunity to go deeper in understanding the science behind the physics. After that I'll teach you how to cheat! #yolo
3 Years Ago by
planetstardragon
jessicalcrichton
jessicalcrichton
Visits: 332
LOL! Thanks! I look forward to it! I figured out, by leaving the character behind so I could see better, that the issue may be that the spiderbot isn't stable and straight. That makes sense with true physics -- that would be the case in reality too with a loose chain -- but I need to make him stable for this. In other words, I need to make this unrealistically loose-chainy but also straight. LOL Ahhh animation! Here's what I mean: https://www.youtube.com/watch?v=zwBr-mR2rjA
