karenkent69
karenkent69
Visits: 173
I am trying to get my character's arms to cross, like in the attached picture. What is the best way to do this? Thanks!
Posts: 4.8K,
Visits: 16.4K
I would check for any already-installed Poses or Animations that are "close" to what you are looking for. Then apply it to the avatar. In the case of an animation... go to the frame that is the closest to the pose you are looking for then Right-Click on the avatar and select "Remove all Animation" that should give you the avatar in the basic pose. Move the Play-Head back to the beginning and then use the "Edit Motion Layer" to refine the pose to what you want.. The "Mirror" feature in "Edit Motion Layer" will be helpful in refining the pose as you go along.
jlittle
jlittle
Last Active: 23 minutes ago
Posts: 1.9K,
Visits: 17.1K
You get get close to what you want by positioning the arms in a crossed position and then use the layer manager to layer the arms and hand correctly. Jeff
Posts: 4.8K,
Visits: 16.4K
I guess I assume incorrectly that people on this section of the forum are working in iClone and the pic was just an example of what they were trying to achieve pose-wise.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
@Mark I know one can't tell which section one is in from a mobile device (at least I can't) but from a desktop it is visible at the top. I know I've made the same mistake and forgot to check which section the post is in before responding. Jeff
