iRay render constantly crashing
Posted By FallenNInja Last Year
FallenNInja
FallenNInja
Posted Last Year
Veteran Member (712 reputation)Veteran Member (712 reputation)Veteran Member (712 reputation)Veteran Member (712 reputation)Veteran Member (712 reputation)Veteran Member (712 reputation)Veteran Member (712 reputation)Veteran Member (712 reputation)Veteran Member (712 reputation)
Posts: 51, Visits: 1.4K
Is anyone experiencing a memory crash while using iRay? This started happening for me after the 1.4 update. Sometimes saving the project as new helps but recently it has stopped helping.
I have reference images posted here: https://www.reallusion.com/FeedBackTracker/Issue/iRay-render-unstable-crashes-at-random-points
If anyone knows a work around or can tell me how to correct this issue it will be greatly appreciated as I have a project which is in the final stage but keep having iRay issues.
planetstardragon
planetstardragon
Posted Last Year
Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)Distinguished Member (21.8K reputation)
Last Active: 10 hours ago
Posts: 11.4K, Visits: 44.9K
i believe there is an issue with how the memory is handled....
i'm finding that when my project is ready to be rendered,  before rendering I save...shut down the program,  then restart it just to render -   this is to flush out the memory that has all the undo data.   I also notice by simply leaving a project open for a long time without use -  ie taking a break and picking things up a few hours later -  also leaves the program unstable - so restarting the program is my current fix for all things crashes - at the very least to help isolate whatever other issues may be present - such as a potentially bad mesh from a prop i imported or a corrupt jpg.
"To define Tao is to defile it" - Lao Tzu
FallenNInja
FallenNInja
Posted Last Year
The only way I was able to prevent this crashing was by removing hidden particle objects and rendering at 720p down from 1080p.
