iRay render constantly crashing
Posted By FallenNInja 7 Months Ago
FallenNInja
FallenNInja
Posted 7 Months Ago
Veteran Member (668 reputation)Veteran Member (668 reputation)Veteran Member (668 reputation)Veteran Member (668 reputation)Veteran Member (668 reputation)Veteran Member (668 reputation)Veteran Member (668 reputation)Veteran Member (668 reputation)Veteran Member (668 reputation)
Posts: 51, Visits: 1.3K
Is anyone experiencing a memory crash while using iRay? This started happening for me after the 1.4 update. Sometimes saving the project as new helps but recently it has stopped helping.
I have reference images posted here: https://www.reallusion.com/FeedBackTracker/Issue/iRay-render-unstable-crashes-at-random-points
If anyone knows a work around or can tell me how to correct this issue it will be greatly appreciated as I have a project which is in the final stage but keep having iRay issues.
planetstardragon
planetstardragon
Posted 7 Months Ago
Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)Distinguished Member (21.1K reputation)
Posts: 11.1K, Visits: 39.1K
i believe there is an issue with how the memory is handled....
i'm finding that when my project is ready to be rendered,  before rendering I save...shut down the program,  then restart it just to render -   this is to flush out the memory that has all the undo data.   I also notice by simply leaving a project open for a long time without use -  ie taking a break and picking things up a few hours later -  also leaves the program unstable - so restarting the program is my current fix for all things crashes - at the very least to help isolate whatever other issues may be present - such as a potentially bad mesh from a prop i imported or a corrupt jpg.
FallenNInja
FallenNInja
Posted 7 Months Ago
The only way I was able to prevent this crashing was by removing hidden particle objects and rendering at 720p down from 1080p.
