Last Active: 4 hours ago
I'll post this in the FT as well, but if you export an avatar from CC3.4 with physics maps on clothing into iClone they do NOT come across (so no physics on clothing in iClone). You need to reload the maps. I didn't try to see if they disappear again upon editing in Character Creator (from iClone) but the devs can test this part out. This is a new bug because it used to work just fine.
donderhaas
donderhaas
Visits: 31
nildoe (3/24/2021) Im having issues loading the free assets of smart-hair... its on a continuous loop.. the suggested workaround to activate in iclone does not work for me either<br/>+1 I have the same issue - when I try to add hair elements via "Content" I am taken to Smart Gallery. Smart Gallery Embedded hair only contains the prev version hair.
3 Years Ago by
donderhaas
Posts: 5.0K,
Visits: 15.9K
Could you possibly share your settings as a work around please.
That is what I have shown there with green arrow at the screenshot
facr73
facr73
Visits: 21.9K
Hi. Mike.
That also happened to me in the previous version.
facr73
facr73
Visits: 21.9K
donderhaas (3/25/2021)
nildoe (3/24/2021) Im having issues loading the free assets of smart-hair... its on a continuous loop.. the suggested workaround to activate in iclone does not work for me either<br/>+1 I have the same issue - when I try to add hair elements via "Content" I am taken to Smart Gallery. Smart Gallery Embedded hair only contains the prev version hair. +1 here
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
nice work on the update, the new features and lighting tweaks are making the native render engine a better option than iray, lots of good detail control now, - for some reason the opacity map on the hair base in iray is not looking proper, it looks jagged and no obvious way to fix that - I tried the basics ..no change ..so I dunno. - I noticed you capped some of the extended morphing to 200, can you uncap that or move it to at least 500 ? it helps for stylized expressions....those caps should be an artists decision ( boundaries bro! ) My favorite tool is the color picker, thank you for that ...it's a game changer for me! cc3 standard render...
3 Years Ago by
planetstardragon
Edward (RL)
Edward (RL)
Visits: 4.8K
Hello,
Try this hotfix for those who have the new hair install issue.
Please read the "HowTo.txt" in the .zip before updating. And if you keep the Smart Gallery in Offline mode when updating to CC3.4/IC7.9. The hotfix install flow should be: 1. Switch the Smart Gallery to Online mode. 2. Close program 3. Run the Hotfix .bat 4. Open the program and click Refresh manually.
Edward
Posts: 5.7K,
Visits: 26.4K
Thank you Edward. The fix has fixed the problem.
ToKoMotion
ToKoMotion
Visits: 30.7K
Yes, work for me as well. Thanks Edward for the quick fix!
________________________________________________ FOLLOW ME:
facr73
facr73
Visits: 21.9K
Hi
It also worked for me too but it's not that simple to follow the hotfix instructions...
Greets
