sumthinwong (4/13/2010)
Not sure if this problem is caused by fbx or 3dxchange....exporting characters or props with applied textures or morphs from Daz causes 3dxchange to crash...removing same transfers ok...anyone have this same problem and know of a solution? Thanks I had problems with 3dchange at first. You really need 'decimator' for your Wavefront.obj props. This makes a huge difference. Now I can bring in almost anything from Daz to x3dchange. In fact if you are willing to 'decimate hard' I'm sure you could bring in anything. I've can also easily add characters via fbx together with animations, although I've not tried that much yet. (Interesting but not always practable). Morph's I've never used but I think duchess is correct on that score.
There is a Daz to 3dxchange tutorial on YouTube, which was very helpful to me as it gave all the correct export setting from Daz. That is defiantly worth a look. (Just use search Daz to 3dxchange).
gizmo
