Python LoadImageToTexture() breaks Motion Live recording
Posted By ziberg 3 Years Ago
ziberg
ziberg
New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)New Member (20 reputation)
Posts: 1, Visits: 19
I'm trying to capture a screen and paste it onto a BillBoard as Texture, while motion live is recording.
I update the  BillBoard's texture with a timer(interval = 1000ms). The python code looks like:
#--------------------------------------------block1--------------------------------------
g_texture_img_file_name = "mooctexture.png"
def refresh_texture_once(g_boardNode, g_material_component, g_mesh_name, g_material_name, g_texture_channel):
    global g_logger, g_texture_img_file_name
    g_material_component.LoadImageToTexture(g_mesh_name, g_material_name, g_texture_channel, g_texture_img_file_name)
    start_prepare_texture_file_thread(g_texture_img_file_name)
class RefreshTextureTimerCallback(RLPy.RPyTimerCallback):
   def __init__(self):
       RLPy.RPyTimerCallback.__init__(self)
   def Timeout(self):
       global g_material_component, g_mesh_name, g_material_name, g_texture_channel, g_boardNode
g_textureTimer = RLPy.RPyTimer()
g_textureTimer.SetInterval(1000)
#textureTimer.SetSingleShot(True)
timer_callback = RefreshTextureTimerCallback()
g_textureTimer.RegisterPyTimerCallback(timer_callback)
def prepare_texture_file(file_name):
    g_selected_screen_index = 0
    current_screen = QtWidgets.QApplication.screens()[g_selected_screen_index]
    rect = current_screen.geometry()
    im = ImageGrab.grab(bbox=(rect.x(), rect.y(), rect.x()+rect.width(), rect.y()+rect.height()), include_layered_windows=False, all_screens=True)
    width = im.size[0]
    height = im.size[1]
    im = im.resize((int(width * 0.3), int(height * 0.3)), Image.ANTIALIAS)
    im.save(file_name)
def start_prepare_texture_file_thread(file_name):
    th = threading.Thread(target=prepare_texture_file, args=(file_name,))
    th.start()
avatar = RLPy.RScene.FindObject( RLPy.EObjectType_Prop, "BlackBoard") #a BillBoard in iClone with the name "BlackBoard"
g_boardNode = avatar
g_material_component = avatar.GetMaterialComponent()
mesh_list = avatar.GetMeshNames()
g_mesh_name = mesh_list[0]
material_list = g_material_component.GetMaterialNames(g_mesh_name)
g_material_name = material_list[0]
g_texture_channel = RLPy.EMaterialTextureChannel_Diffuse
g_textureTimer.Start()
The (real) code in block1 works well, capturing the screen and pasting it on the BillBoard every 1 second.
However, when i start the Motion Live (a GREAT work!), click the "Record" button and press SpaceBar,
 the Motion Live begins, and STOPS when the g_textureTimer executes the Timeout().
It seems that, the timer stops the Motion Live's thread, since they both update the scence in iClone.
The initial purpose is to import a video stream into the scence in iclone while previewing/recording the Motion Live.
However, the RIMaterialComponent.LoadVideoToTexture() has no RTSP file format options.
When i load the RTSP(rtsp://127.0.0.1:8554/test.mpg) with the following python code:
ret = g_material_component.LoadVideoToTexture(key, g_mesh_name, g_material_name, g_texture_channel, "rtsp://127.0.0.1:8554/test.mpg")
The ret is Sucess, iClone accepts it, but the BillBoard is blank(white).
By the way, the [rtsp://127.0.0.1:8554/test.mpg] is produced by live555MediaServer.exe and can be viewed in VLC.
And the original movie file can be loaded as texture:
g_material_component.LoadVideoToTexture(key, g_mesh_name, g_material_name, g_texture_channel, "D:/live555/test.mpg")
So my question is:
1) Is it possible to import a RTSP stream as a video texture;
2) or is it possible to update the texture without interrupting Motion Live, and how?
