josterday
josterday
Visits: 176
Is it possible to import a Daz Head into CC3 and maintain all of the facial joints? From what I've tested so far, Transformer will always auto-rig with the CC3/UE4 Mannequin joint setup - removing the additional Daz facial joints and replacing with Blendshapes. This results in transform and naming changes along with deletion of necessary joints for facial capture. In order to utilize high-end facial solvers for mocap, CC3 characters need to have a control rig that exists in Maya for proper retargeting (which would be a mixture of blendshapes and joints). Daz now has this (thanks to the Face Control plugin), so we need an option to maintain facial rigging without losing all of the Reallusion features/pipeline such as Skingen, Headshot, etc. Any thoughts on how to potentially make this happen?
Posts: 10.8K,
Visits: 40.2K
You transform it into a CC Morph and not import a DAZ Mesh. It's like projecting. CC is a Base Mesh that only change the geometry data, not more.
josterday
josterday
Visits: 176
Can you elaborate on this? If I create a DAZ morph in CC3 via the iAvatar process, then I’m still starting with a base mesh (CC3 or CC3+) which does not include the necessary facial joints.
I need to convert DAZ characters to CC3 in order to take advantage of the Unreal joint hierarchy / naming convention, but the facial joints need to remain from DAZ since they have a Control Rig associated with them in Maya.
My hope is that there’s a 3DX or iClone option somewhere that allows me to create a custom CC3+ character with those added joints but utilizes the topology of CC3 for the sake of SkinGen and Headshot
AutoDidact
AutoDidact
Last Active: 20 minutes ago
Posts: 1.9K,
Visits: 12.1K
As was stated, CC3 only exmaines the shape of the imported Daz FBX and Creates a morph for a CC3 base Avatar that looks like the Daz figure. The Daz figure and its rigging is completely discarded after this process. If you need that Daz facial rig in UE4 or Maya you need to export an FBX from Daz Studio to those apps and sort it out from there. If you need the use Reallusions Headshot or Skin gen you need to use the natve CC3 avatars for which those feature were designed.
DS-Waqas
DS-Waqas
Visits: 284
@josterday Use the DazToUnreal plugin which is free via their Daz Central. Then its just a matter of using the retargeting tools in Unreal to allow you use any and all Unreal Mannequin compatible animations. This way you are preserving the DAZ rig as well.
3 Years Ago by
DS-Waqas
josterday
josterday
Visits: 176
@AutoDidact - thanks for the (unfortunate) confirmation. It makes sense that SkinGen/Headshot are strictly built around CC3 topology and rigging.
@DS-Waqas - I'm familiar with the plugin, but that removes SkinGen/Headshot support as mentioned. Reallusion's Auto-Import tool for UE4 does a good job of setting up all the materials, retargeting, physics, etc. Now, I will say the DAZ plugin has a nice Anim BP for JCMs that comes over with the transfer.
I was hoping to approach this character setup with Daz as the source art platform (similar to ZBrush) with CC3 providing final rigging and FX. Having a Mannequin-based rig is a huge benefit to mocap pipelines and other UE4 assets. As it stands, you can't have high-end facial with a CC3 character in UE4, unless you build a Control Rig in Maya by hand. That's a major setback as we see wider adoption of facial solves beyond ARKit/iPhone.
