Exported characters lost their eyes. How to fix it?
Posted By fwindorochi2k Last Year
fwindorochi2k
fwindorochi2k
Posted Last Year
Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)Junior Member (146 reputation)
Posts: 2, Visits: 86
https://forum.reallusion.com/uploads/images/30f87221-0b3c-4916-b7f6-d313.jpg
First time noob user here. I was trying to export a character made in Character Creator 3 to an obj file so that I can then upload this character to mixamo to do the animation.
However, it seems all the characters I export from Character Creator 3 having their eyes turned white.
Anything I can try to fix this?
Thanks!
fwindorochi2k
fwindorochi2k
Posted Last Year
I find a hack fix by delete eyeocclusion.
Eyes somehow now shows up in blender.
But, it feels not the right way to do it.
Is there any better way to fix this issue?
new-own
new-own
Posted Last Year
Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)Veteran Member (589 reputation)
Posts: 42, Visits: 204
They work fine in older versions of Blender but not the 2.90+ ones. I cannot find the reason or the solution either..
Smit_R
Smit_R
Posted Last Year
Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)
Last Active: 13 hours ago
Posts: 32, Visits: 1.3K
Isn't this just a texture transparency issue?
I guess your in Eevee render mode.
Select eyeocclusion in object mode > Material tab > Select std_eye_occlusion_r (and l) > Settings > Change Blend Mode from Opaque to Alpha Blend.
Same goes for Hair, Eyelash and Tearline.
When using Cycles render the transparency is already setup correctly.
Posted Last Year
Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)
Last Active: 41 minutes ago
Posts: 13.7K, Visits: 24.5K
I'm not a regular Blender user, but I also seems to remember that the renderer needed to be set to Cycles while importing. At least, the render setting had an influence. Correct if I'm wrong...Unsure
https://forum.reallusion.com/uploads/images/1f3bed13-1788-45e1-9ace-4fd0.jpg
Smit_R
Smit_R
Posted Last Year
@Animagic There is no option for importing objects to Cycles or EEVEE in Blender. You can change the type of render on the fly in the Blender-file.
While the material settings are correctly setup in Cycles (which you can even adjust further more), you must change some settings for use in EEVEE to be displayed properly.
jlittle
jlittle
Posted Last Year
Last Active: 4 hours ago
Posts: 1.7K, Visits: 15.1K
The issue with the Eye Occlusion not working in Blender 2.91 but working in 2.90 stems from the Eye Occlusion shader connections.
If you re-route the Alpha channel from the BSDF shader to the Color output instead of the Alpha output of the Opacity map it will correct the issue.
The same issue also applies to the Eyelashes.
Blender 2.90 routes the BSDF Alpha to the image Color channel which must have been a bug since in 2.91 the BSDF Alpha channel is routed to the image Alpha channel.
Jeff
Last Year by jlittle
Watson Prunier
Watson Prunier
Posted 9 Months Ago
New Member (40 reputation)New Member (40 reputation)New Member (40 reputation)New Member (40 reputation)New Member (40 reputation)New Member (40 reputation)New Member (40 reputation)New Member (40 reputation)New Member (40 reputation)
Last Active: 5 Months Ago
Posts: 2, Visits: 22
Wow! Thank you! I needed this!
hamedazhang085
hamedazhang085
Posted Last Month
New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)New Member (11 reputation)
Posts: 1, Visits: 1
I tested FBX cc3  exported in all 3D software including Marvelouss, Unreal Engine, Lumion, Fuse &... But unfortunately the problem of not showing the pupils was obvious in all of them. It is really a big Defect for CC3 software
Last Month by hamedazhang085
