declanwalshart
declanwalshart
Visits: 69
Hi, Many thanks for allowing me the opportunity to look at this process early. I was getting to grips with it today, and just one thing kept coming up for me. Some limbs foreshorten, it would be amazing if the torso and hands did this. My main question is there a way to have the body switch from front to 45, to the side so the motion created in 3d like a turn could be mimicked in 2d without swapping out the angles.
Hope that makes sense Thanks Declan
kylelee
kylelee
Visits: 4.2K
declanwalshart (11/18/2020) Hi, Many thanks for allowing me the opportunity to look at this process early. I was getting to grips with it today, and just one thing kept coming up for me. Some limbs foreshorten, it would be amazing if the torso and hands did this. My main question is there a way to have the body switch from front to 45, to the side so the motion created in 3d like a turn could be mimicked in 2d without swapping out the angles.
Hope that makes sense Thanks DeclanThank you for your feedback. Currently, you can switch show/hide to change different angle characters such as from front to 45 degrees.
4 Years Ago by
kylelee
declanwalshart
declanwalshart
Visits: 69
Hi, Thanks for that, a good idea I didn't think of. I will run a test on this All the best Declan
studio.diba
studio.diba
Last Active: 5 Months Ago
Visits: 125
Hi Declan, You start with a side pose, switch to a front pose in the middle and end with a filp of the side pose.
declanwalshart
declanwalshart
Visits: 69
Hi, Thanks for that, I can see it now
kylelee
kylelee
Visits: 4.2K
studio.diba (11/19/2020)
Hi Declan, You start with a side pose, switch to a front pose in the middle and end with a filp of the side pose. You can try enable the "Flip body" when applying 3D motion that will easier to do switch front to side.
4 Years Ago by
kylelee
