silly Problem with texture on objects
Posted By Evey Fawkes 4 Years Ago
Evey Fawkes
Evey Fawkes
Posts: 97, Visits: 589
Hello,
Whenever I try and apply a picture of a texture to an object, I run into problems.
In this example, I tried applying a pic of a tree to a simple selfmade object.
I tried it first with an object of 1x1 dimensions.
Top of the tree disappeared from the object. (it is in the reference picture)
Then I tried adapting the size of the picture to the object. (and UV unwrapped it before applying to iClone)
That didnt work either. I tried the UV offset in iC7 "modify" but that didnt work either. i could slide the image to right and left, but not scale it so that it would fit an 1x1 (UV unwrapped) object.
Is there a general rule I need to follow? I am intending to fill a garden with plants, using basic planes on which I want to project the Png's.
I've been running into this problem many times.
Hoping for someone to help me out. This must be a simple thing I am overlooking.
Grateful for you help.
including a screenshot. https://forum.reallusion.com/uploads/images/b0807673-d55f-45a4-9112-a057.jpg
mark
mark
Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)Distinguished Member (12.1K reputation)
Posts: 4.8K, Visits: 16.4K
Did you create a reference UV texture map of your object when you created it in your modeling program? If so, your texture map should be based on that reference map.
At least I think that's what's happening.
PROMO-BACK2
