tkamal81 (11/3/2020)
can you from move rotate scale 3d objects or 2d objects inside iclone in a frendly way like that we can do in 2d explainer videosYes you can do that easily using the Transform tools.
i mean click of few button object starts to move from one place to another bounces staggers ping pong etc
There are not one click buttons that do this but it can be easily achieved using keyframe animation
can u add fade or transition effects like in powerpoint
See my answer to your "explainer" question below.
can you add 3D text or text objects with extrude bevel in iclone
iClone doesn't have a 3D text tool but you can import 3D text as props using 3DXchange or using 3D text content packs. You can also easily apply image overlays with 2D text.
what is the easy way to create explainer videos in iclone
is there a separate plugin for that..
Creating explainer videos in iClone is the same as creating explainer videos in any software. You will first have to build your scenes, add characters, add spoken text or use overlays. However, you will probably find it easier to create one scene per project and then add transition effects, fades etc in a video editor after your iClone projects have been rendered to video. There is not a separate "Explainer" plug-in but you may find the PopcornFX plug-in very useful in creating a huge variety of effects for your scenes.
