mondhillon
mondhillon
Visits: 19
When I bring a G2 front character onto the scene, I am first asked what angle I would like the character at, but whatever angle I choose, the character still remains at 0 degree (front angle).Even when I go into the 3D motion key editor, the character will not rotate with the angle that I am choosing, the arms and legs make little goofy movements but the body does not rotate, I do check-off the rotate button. See the attached movie file to see the sequence that I follow. Please let me know what I am doing wrong.
4 Years Ago by
mondhillon
jlittle
jlittle
Last Active: 8 minutes ago
Posts: 1.9K,
Visits: 17.1K
Those look to be G1 characters with each one being at a different angle. When you open a G1 character it will try to convert to a G2 character so select the angle that is closest to that at which it is drawn. Even though it will be converted to a G2 character it will not have all the angles properly defined since that info was not available. With some work you could possibly build a full G2 character from the multiple G1 character angles. Jeff
