Hotkey for "Frame Selected" (camera navigation going close to selected item, without changing view...
Posted By cgi_468384 2 Months Ago
Hotkey for "Frame Selected" (camera navigation going close to selected...
cgi_468384
cgi_468384
Posted 2 Months Ago
Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)Junior Member (247 reputation)
Posts: 24, Visits: 70
Normally is F used for "frame selected".
So it needs maybe another hotkey, which frames the selected item, just by dollying closer with the camera (and not changing angle).
In bigger scenes is navigation very hard, when you want to see an object close from the same perspective angle.
Also it's a standard function which people are used for camera navigation.
0oseven
0oseven
Posted Last Month
Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)Veteran Member (538 reputation)
Posts: 73, Visits: 224
cgi_468384 (8/22/2020)
Just discovered if right click object and then select the "home" icon, it will zoom in on that object.
Also works if object selected in the scene tab BUT NOT with lights.
However  multiple camera views on screen at the same time.[ I requested this in earlier post ] I believe is essential in scene management. Common in most apps.
Last Month by 0oseven
