body color different from head
Posted By VRTeacher Last Year
VRTeacher
VRTeacher
Posted Last Year
Veteran Member (553 reputation)Veteran Member (553 reputation)Veteran Member (553 reputation)Veteran Member (553 reputation)Veteran Member (553 reputation)Veteran Member (553 reputation)Veteran Member (553 reputation)Veteran Member (553 reputation)Veteran Member (553 reputation)
Posts: 35, Visits: 451
In CC3.3, I use headshot pro to create a character. At first the color of the head (except the face) is the same as the rest of the body.
Then, I fine tune morphs using 'activate image matching tool' and Re-Project Photo. No masks on. And repeat several times.
So far the body color is consistent with the head:
https://forum.reallusion.com/uploads/images/c6c56b68-86af-47d4-9dd1-b05c.jpg
Then, I add a face mask (default even) with or without eyelid mask. In this step, somehow the color of the body neck and below becomes distinctly different from the head. I don't know why but this has happened to me several times now.
https://forum.reallusion.com/uploads/images/551bf632-48b4-423d-9565-c3f5.jpg
I try manually changing 'Skin Color' to match the body color to the face, which is successful,
but then the head color (except face) becomes too different from the face/body color as follows:
https://forum.reallusion.com/uploads/images/1569ad4f-69d7-4b1e-9162-d742.jpg
Is this because I use an Asian photo in headshot?
Or is there some other reason for this?
In any case, please teach me how to get around this color mismatching problem.
Thanks in advance.
Last Year by VRTeacher
Posted Last Year
Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)Distinguished Member (26.0K reputation)
Last Active: 5 hours ago
Posts: 13.8K, Visits: 24.5K
It looks like a bug. The ethnicity of the source photo shouldn't matter.
https://forum.reallusion.com/uploads/images/1f3bed13-1788-45e1-9ace-4fd0.jpg
VRTeacher
VRTeacher
Posted Last Year
animagic (8/9/2020)
Thanks for the quick response.
If it's a bug regardless of ethnicity, how come no one has yet to point this out? (I couldn't find any post on this matter!)
Were you aware of this bug?
Zeronimo
Zeronimo
Posted Last Year
Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)Distinguished Member (3.0K reputation)
Last Active: 1 minute ago
Posts: 392, Visits: 16.0K
on your last image, I don't see anything that is very normal.
The tool you use there only deals with the skin of the face and not the body.
it has other tools outside of Headshoot which allow you to modify the body color
https://forum.reallusion.com/uploads/images/f5a37429-509b-4df6-8afb-3ed4.jpg
Last Year by Zeronimo
VRTeacher
VRTeacher
Posted Last Year
Zeronimo (8/9/2020)
The "Skin Color" in Headshot does deal with the skin of the head (except face) and the body.
In headshot, go make any changes to the skin color and you'll see what I mean.
The skin color adjustment is in the headshot in order for you to change the skin color of the body and head (except face) when you happen to modify the face skin color in headshot.
So the unintended change of the skin color of the body (but not the head) while you're still working on the headshot is defeating the purpose of having "skin color" adjustment of body and head (except face).
I'm currently experimenting to see exactly when the skin color of the body erroneously changes as shown in my second picture above.
Originally when I posted the question, I thought it changed right after I added the face mask. But I was wrong about that.
It changed only after I edited the Photo Diffuse file on Photoshop and updated Skin Texture.
(Editing Blend Mask doesn't seem to change the color of the body skin!)
Zeronimo (8/9/2020)
Appearance Editor cannot rectify this error, because in CC3+ the head skin includes neck as well as the head (and face).
As shown in my second picture above, the problem lies in the fact that the skin color of the neck becomes different from that of the head.
Changing the skin color of the head in Appearance Editor will only change the head AND neck at the same time.
VRTeacher
VRTeacher
Posted Last Year
VRTeacher (8/9/2020)
I stand corrected.
The culprit is not the Photo Diffuse editing.
It's "Update Skin Texture".
The worst part is the color change is random.
Sometimes the color of the body (neck and below) doesn't change after several times you "update skin texture" with adding masks, but if you repeatedly "update skin texture" with different masks, the color does change even though you don't even touch Photo Diffuse.
Posted Last Year
Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)Distinguished Member (13.1K reputation)
Posts: 3.6K, Visits: 13.4K
It was already pointed out at the forum and more importantly reported to FT: https://www.reallusion.com/FeedBackTracker/Issue/Skin-below-head-gets-brighter-with-each-Update-Skin-Texture
TonyDPrime
TonyDPrime
Posted Last Year
Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)Distinguished Member (10.3K reputation)
Posts: 3.2K, Visits: 11.1K
4u2ges (8/9/2020)
VRTeacher, this has been mentioned forums already, I myself have brought this up in the CC 3.3 Technical issues post
https://forum.reallusion.com/FindPost452729.aspx
https://forum.reallusion.com/FindPost453371.aspx
It seems it has to do with the "old CC3 head" and the "old CC3 body" now having been joined in a single head map with the neck now being a part of the head map, and a saturation bug.
But to 4u2ges point, do not hesitate to post and report your findings in the Feedback Tracker.  It will help RL track the progress of outstanding issues.  Also, others may have found their own workarounds or just are too lazy to post in Feedback Tracker if they found it does not matter so much.  So if you do care, then you can always make the Feedback Tracker post yourself, and then share that Feedback Tracker post with the forum, like 4u2ges did.
