Eric C (RL)
Eric C (RL)
Visits: 5.2K
Iray v1.4 - Performance Enhancement
Announcing the update for Iray v1.4: - Enhanced: Support for MDL 1.5, please visit nVIDIA website for more information.
- Enhanced: Update Iray SDK to RTX 2019.1.5. This will improve render speed from 0 - 106% performance increase according to the MDL versions used.
See the two benchmark tests for Iray render speed comparison below.
Eric C (RL)
Eric C (RL)
Visits: 5.2K
#Test 1
- Hardware spec:
- CPU: i7-7700
- Memory: 16G RAM
- Graphic Card: GTX 1070 / 8G
- Project: IC Embedded Project - Loft scene & Iray Export Settings
- When using Iray 1.3 ( IC 7.7) and set the render time as 3,600 seconds, we get 486 iterations:
- When using Iray 1.4 ( IC 7.7) and set the render time as 3,600 seconds, we get 593 iterations:
- As a result, the project has improved render speed of 22%.
#Test 2
- Hardware spec:
- CPU: i7-9750
- Graphic Card: Quadro RTX 5000 / 16G
- Memory: 64G RAM
- Project: IC Embedded Project - Roma scene
- When using Iray 1.3 ( IC 7.7) and set the render time as 1,169 seconds, we get 1,000 iterations:
- When using Iray 1.4 ( IC 7.7) and set the render time as 565 seconds, we get 1,000 iterations:
- As a result, the project has improved render speed of a whopping 106%!!!!
Geoffrey James
Geoffrey James
Visits: 346
Just for the heck of it I ran the Loft Scene benchmark, as defined above, on my dual RTX Titans. It did 1,000 passes in 763 seconds using the most recent version of the iRay renderer. I must be doing something wrong. Any suggestions?
Geoffrey James Intel Core i9-9980XE 18 Cores @ 4.5GHz, 128GB @ 3000MHZ, 2 NVIDIA® TITAN RTX, 512GB SSD, 2TB SSD, 10TB HDD, 1200 Watt PS, Viewsonic 43" 4K.
4 Years Ago by
Geoffrey James
