Last Active: 10 hours ago
Visits: 62.5K
ahingel (9/29/2020)
oh my god i cant believe it that was it !!! it worked i just copying pasting the path from the properties of the file and it was using \ instead of / THANK YOU SO MUCH ❤😁😁😁😁😁😁😁😁❤❤❤❤❤❤❤❤❤❤❤ I caught on to that one pretty slowly too! LOL
Posts: 5.3K,
Visits: 16.4K
lol... Sorry folks, the slashes direction does not matter (at least on my computer) At some point I though it does. And then I figured the problem was elsewhere but left slashes as is. It works either way for me
4 Years Ago by
ahingel
ahingel
Visits: 423
haha omg i did it with a cube but i couldnt import the ocean and make it work as you did. because i got the error message for 20000 verts on iclone . and i thought it has to be under 20000 what was the other false you found?
Posts: 5.3K,
Visits: 16.4K
You just click OK and disregard that error. Ocean still gets Soft Cloth status regardless
Visits: 62.5K
It's just a warning, to keep performance good. You can use more though. If you used a cube before, that's why it would not work. You need to import the same prop as an OBJ that you saved as Alembic. Make sure it has the same name too. You can change the name by double-clicking it in the Scene Manager if you need to. You can also un-check the physics for just that prop after loading the Alembic.
4 Years Ago by
ahingel
ahingel
Visits: 423
finally i got it moving too 😁😁😁 on the script i just cut off some spaces and finally it worked thank you guys for your help ❤❤❤❤❤
import RLPyfile_path = "C:/Users/Achil/Desktop/ocean.abc" object = RLPy.RScene.FindObject(RLPy.EObjectType_Prop,"Plane") RLPy.RFileIO.LoadAlembicFile(object,file_path, RLPy.ECoordinateAxis_Y)
Posts: 5.3K,
Visits: 16.4K
4 Years Ago by
Posts: 5.3K,
Visits: 16.4K
Just to be even more clear:
Posts: 5.3K,
Visits: 16.4K
Good!
Posts: 5.3K,
Visits: 16.4K
Just a word of advise for those making oceans. Make a loop sim. Here is how to easily make an *extendable* sim with 2 ocean modifiers:
