Hayzie (5/15/2020)
Sure. After playing with the CA-AE plugin I can see it's going to be a big time saver.
My workflow was pretty much the manual process of what the plugin is going. I'd export out all the layers and reimport into AE. Then I could do any little post effects I wanted ie. blurring the background or colour grade.
I haven't tried moving the audio from CA to AE with the plugin yet but if that comes across that will help too. Doing it manually meant I had to slide the audio until it was in sync.
Thank you for your testing, I am glad to hear AE plugin can help your workflow.
I have another question, do you need a feature of updating between CTA and AE so that you can replace an character and keep motion in CTA then exporting to AE to do post render?
