Can you use the Mocap with out the plugin?
Posted By kmitchell.12catblackstudio... 4 Years Ago
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Posts: 257, Visits: 1.1K
Would it work If I get the Perception Neuron v2 with out the plugin now and later when i can afford it get the plugin later? I assume I can still use 3DXChange to bring in saved data from the Axis Neuron Software. From the look of it the jitter cleanup is an IClone 7 feature not necessarily the plugin correct?
Posts: 9.2K, Visits: 21.8K
This is correct -- in fact, although I do have Motion live AND the PN plugin I actually rarely use it that way but use the Neuron software in the exact way you describe (you actually have to run the Neuron software in the background anyway to feed the PN plugin into iClone).
Using the Neuron software in this manner also means you can use the cleanup process inside of that software, so I do think it comes out better than just feeding it to iClone.
