Customize G3 Motions
Posted By boris.degenhardt 4 Years Ago
boris.degenhardt
boris.degenhardt
Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)Veteran Member (549 reputation)
Posts: 15, Visits: 83
Hi,
is there any way to customize any of the G3 Human motions stuff, if I e.g. want to change the head position or similar? Something like an individualization per character?
Best regards
Boris
kylelee
kylelee
Posts: 462, Visits: 4.2K
You can use the PSD workflow to create customize characters.
if you create some props also can attach to the character as accessories.
Here is the tutorial:
https://www.youtube.com/watch?v=SdSxWIwaPlY
https://youtu.be/CRfRcusWiFw
Posts: 22.7K, Visits: 35.7K
Hi Boris
If you want to customise the G3 motions you can do so using the "2D Motion Key Editor" which is available from the left toolbar in Stage Mode or by pressing K.
Once you have applied a motion to your character, open the 2D Motion Key Editor. Then scrub the play bar to the frame you want to edit and then make changes such as moving the head, legs or arms. Please see the page below for more information on how to use the 2D Motion Key Editor.
 https://manual.reallusion.com/Cartoon_Animator_4/ENU/Pipeline/Content/Resources/ENU/08_Animation/Body_Puppeteering/Using_Body_Key_Editor.htm
boris.degenhardt
boris.degenhardt
Hi Peter,
thanks for your answer, any opening of predefined motion clip is not possible? To rebuild and reach similar quality as the prebuilded motions it would be great to have a deeper look in keyframes and transitions that are used.
Best regards
