rino.deastis
rino.deastis
Visits: 32
Hi, I take some important characters from deviantart in ascii.mesh. After more days of debugging i found a way to open them , i can have them a fantastic mesh of the character in OBJ and separate texture files, but if i load the obj the textures are not applied to the meshes. Any idea to "search and apply" the textures to the character? I was able to do it in the past with another modeler software that was able to ask the name of the testure for browse it in the hard disk but unfortunately it does not work on Windows 10, any idea for cc3? all the best Kind Regards RIno
Last Active: 4 hours ago
Hi Rino Character Creator 3 doesn't support import of custom characters. You can modify the CC3 base mesh in other 3D tools to create morphs and bring that back but you can't just import non-standard characters. For non-standard characters like the one you have, you can use 3DXchange 7 Pro/Pipeline to import the character and then manually apply the textures. However, please remember that if your character is in OBJ format then it won't have a bone rig so will be just a static prop if you send it to iClone or any other 3D software. For a character to be animated it must have a bone rig setup first.
rino.deastis
rino.deastis
Visits: 32
Thank You Very Much Rino
