A few questions from a new user
Posted By abierano 4 Years Ago
abierano
abierano
New Member (42 reputation)New Member (42 reputation)New Member (42 reputation)New Member (42 reputation)New Member (42 reputation)New Member (42 reputation)New Member (42 reputation)New Member (42 reputation)New Member (42 reputation)
Posts: 1, Visits: 5
Hello,
I am going through the tutorials and learning to create projects, but ran into a few scenarios that I can't figure out:
1. When I add a character or prop and start adding animation, I can't move the prop or character to another position on the project without creating a new motion. I feel like there is something that I need to select or deselect to be able to move props without adding motions. I circled the motions in the screenshot below that I'm referring to.
https://forum.reallusion.com/uploads/images/09222389-25ba-480f-a213-897a.png
2. When these motions from the screenshot ARE created, how do you delete them?
3. On different projects that I've been working on, at some point it doesn't allow me to use the right click action menu. I used this to add multiple actions for the character in the picture below and then midway through the project the menu stopped diplaying and only the "action menu editor" option came up.
https://forum.reallusion.com/uploads/images/04611bb7-f9b6-4215-a795-9b03.png
Thank you for any assistance!
kylelee
kylelee
Posts: 462, Visits: 4.2K
Here is my testing, provide to you as a reference.
(1) I cannot reproduce your issue.
(2) You can open the timeline and expand the transform track, you will see the transform key, you just delete the key the point will be removed.
https://forum.reallusion.com/uploads/images/7f5374d2-854d-4969-9ac7-36bd.gif
(3) As I know, the CTA3's Ted does not have an Action menu, please make sure your actor.
Or you can record a video then pass to Feedback Tracker for further investigation.
4 Years Ago by kylelee
Last Active: 11 hours ago
Posts: 22.7K, Visits: 35.7K
abierano (3/30/2020)
Do make sure that you position all characters and props @ frame 1 on the timeline. If you move characters or props about other than at frame 1 you will be setting transform keys (the dots and green lines). The result of this will be that when you play the project the character or prop will transition from the initial position @ frame 1 to the new position.
