Texture appear washed when ecported to Unreal Via Live Link {pictures}
Posted By Eshekieri 2 Months Ago
Texture appear washed when ecported to Unreal Via Live Link {pictures}...
Eshekieri
Eshekieri
Posted 2 Months Ago
Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)Junior Member (232 reputation)
Posts: 6, Visits: 104
HI,
i need help understanding how to get the textures looking good within UE4. the textures appear to washing out in ue4 but they look good within Iclone. I used the automatic setup with HQ textures.
https://forum.reallusion.com/uploads/images/3bd9833f-44c3-42ad-aadc-9ae0.png
6th gen I7, 16Gb RAM, GTX 1060 and a lot of Brain Power.
2 Months Ago by Eshekieri
unit23
unit23
Posted 2 Months Ago
Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)Veteran Member (694 reputation)
Last Active: 3 days ago
Posts: 86, Visits: 316
Eshekieri (3/24/2020)
HI,
This could be due to several things, for instance if Unreal Engine is running under heavy load (depending on your computer specs, and current tasks), it scales visuals down. Closing asset panels, checking the engine quality settings, running the project, or exporting it may offer more clues.
Reallusion Unreal Engine Technical Expert / LEGENDS of EPICA
Bassline303
Bassline303
Posted 2 Months Ago
Last Active: 42 minutes ago
Posts: 414, Visits: 4.7K
Also take a look which RL Shaders are loaded , especially the Eyes need to have the RL_EyeRefractive Shaders.
Sometimes the Character has only the RL_Standart Shaders loaded , switch to RL_HQShaders.
Material Tap / at the bottom :
https://forum.reallusion.com/uploads/images/db552184-0c70-4b06-bd2e-4d7b.jpg
Eyes :
https://forum.reallusion.com/uploads/images/3d59a9bf-8843-49ed-933b-6c6b.jpg
Also deactivate "Auto Exposer" in Project Settings.
And rebuild your lights after changing or switch all light sources to moveable.
Eshekieri
Eshekieri
Posted 2 Months Ago
You were right on the money. Thank you.
this is true for all other textures, all i had to do is manually affix all the HQ textures for the head, body hands and now the characters looks decent enough to proceed with confidence.
Thank you for the informationhttps://forum.reallusion.com/uploads/images/6dff7c44-d844-446e-af79-0774.png
nikofilm
nikofilm
Posted 2 Months Ago
Veteran Member (950 reputation)Veteran Member (950 reputation)Veteran Member (950 reputation)Veteran Member (950 reputation)Veteran Member (950 reputation)Veteran Member (950 reputation)Veteran Member (950 reputation)Veteran Member (950 reputation)Veteran Member (950 reputation)
Posts: 79, Visits: 1.7K
Hello!
In the photo on the right, I see a character carrying objects.
How did you attach the items to the character in Unreal?
Bassline303
Bassline303
Posted 2 Months Ago
@ nikofilm
1.  Switch object that you want to attach from static to moveable
https://forum.reallusion.com/uploads/images/ec42204c-a896-441a-8958-32c5.jpg
2.  left click on object - attach
3   In sequencer you can keyframe attach and detach.
Eshekieri
Eshekieri
Posted 2 Months Ago
Hi,
This worked by accident, i was trying to make the props export with Livelink to UE4 and I stumbled on the precept that using the ATTACH function allows livelink to export your character together with the prop. So aside from linking your prop you may also try attaching it to the corresponding bone and live link will export the prop.
https://forum.reallusion.com/uploads/images/2221830e-54e0-4ed4-93b6-8a2c.jpg
Procrastinator
Procrastinator
Posted 3 Weeks Ago
Junior Member (119 reputation)Junior Member (119 reputation)Junior Member (119 reputation)Junior Member (119 reputation)Junior Member (119 reputation)Junior Member (119 reputation)Junior Member (119 reputation)Junior Member (119 reputation)Junior Member (119 reputation)
Posts: 19, Visits: 451
What is the lighting settings that you guys used for unreal to get realistic iclone textures?
Eshekieri
Eshekieri
Posted 3 Weeks Ago
After you have set up your lights in the locations you want them. try adjusting the lightmass settings under world settings just before you build your lighting. Ensure you are on production quality when you build.
https://forum.reallusion.com/uploads/images/264ea6ba-045d-42b5-a161-188.jpeg
Procrastinator
Procrastinator
Posted 3 Weeks Ago
Thanks for the info. I dont bake lighting so i tried RTX (for the first time using super 1660). The texture looks great under the rtx lighting.
https://forum.reallusion.com/uploads/images/94a7e9a5-23d0-46b3-a68a-ffdb.jpg
3 Weeks Ago by Procrastinator
