Texture appear washed when ecported to Unreal Via Live Link {pictures}
Posted By MuriithiNyaga 4 Years Ago
Texture appear washed when ecported to Unreal Via Live Link {pictures}...
MuriithiNyaga
MuriithiNyaga
Veteran Member (552 reputation)Veteran Member (552 reputation)Veteran Member (552 reputation)Veteran Member (552 reputation)Veteran Member (552 reputation)Veteran Member (552 reputation)Veteran Member (552 reputation)Veteran Member (552 reputation)Veteran Member (552 reputation)
Posts: 17, Visits: 360
HI,
i need help understanding how to get the textures looking good within UE4. the textures appear to washing out in ue4 but they look good within Iclone. I used the automatic setup with HQ textures.
https://forum.reallusion.com/uploads/images/3bd9833f-44c3-42ad-aadc-9ae0.png
Ryzen 9 3900x, 64Gb RAM, GTX 1080 and Cerebro's Core Specs
4 Years Ago by Eshekieri
unit23
unit23
Posts: 115, Visits: 380
Eshekieri (3/24/2020)
HI,
This could be due to several things, for instance if Unreal Engine is running under heavy load (depending on your computer specs, and current tasks), it scales visuals down. Closing asset panels, checking the engine quality settings, running the project, or exporting it may offer more clues.
Bassline303
Bassline303
Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)Distinguished Member (13.4K reputation)
Last Active: 3 hours ago
Posts: 5.6K, Visits: 13.9K
Also take a look which RL Shaders are loaded , especially the Eyes need to have the RL_EyeRefractive Shaders.
Sometimes the Character has only the RL_Standart Shaders loaded , switch to RL_HQShaders.
Material Tap / at the bottom :
https://forum.reallusion.com/uploads/images/db552184-0c70-4b06-bd2e-4d7b.jpg
Eyes :
https://forum.reallusion.com/uploads/images/3d59a9bf-8843-49ed-933b-6c6b.jpg
Also deactivate "Auto Exposer" in Project Settings.
And rebuild your lights after changing or switch all light sources to moveable.
MuriithiNyaga
MuriithiNyaga
You were right on the money. Thank you.
this is true for all other textures, all i had to do is manually affix all the HQ textures for the head, body hands and now the characters looks decent enough to proceed with confidence.
Thank you for the informationhttps://forum.reallusion.com/uploads/images/6dff7c44-d844-446e-af79-0774.png
nikofilm
nikofilm
Last Active: 10 hours ago
Posts: 314, Visits: 4.3K
Hello!
In the photo on the right, I see a character carrying objects.
How did you attach the items to the character in Unreal?
Bassline303
Bassline303
@ nikofilm
1.  Switch object that you want to attach from static to moveable
https://forum.reallusion.com/uploads/images/ec42204c-a896-441a-8958-32c5.jpg
2.  left click on object - attach
3   In sequencer you can keyframe attach and detach.
MuriithiNyaga
MuriithiNyaga
Hi,
This worked by accident, i was trying to make the props export with Livelink to UE4 and I stumbled on the precept that using the ATTACH function allows livelink to export your character together with the prop. So aside from linking your prop you may also try attaching it to the corresponding bone and live link will export the prop.
https://forum.reallusion.com/uploads/images/2221830e-54e0-4ed4-93b6-8a2c.jpg
Procrastinator
Procrastinator
Veteran Member (805 reputation)Veteran Member (805 reputation)Veteran Member (805 reputation)Veteran Member (805 reputation)Veteran Member (805 reputation)Veteran Member (805 reputation)Veteran Member (805 reputation)Veteran Member (805 reputation)Veteran Member (805 reputation)
Posts: 76, Visits: 980
What is the lighting settings that you guys used for unreal to get realistic iclone textures?
MuriithiNyaga
MuriithiNyaga
After you have set up your lights in the locations you want them. try adjusting the lightmass settings under world settings just before you build your lighting. Ensure you are on production quality when you build.
https://forum.reallusion.com/uploads/images/264ea6ba-045d-42b5-a161-188.jpeg
Procrastinator
Procrastinator
Thanks for the info. I dont bake lighting so i tried RTX (for the first time using super 1660). The texture looks great under the rtx lighting.
https://forum.reallusion.com/uploads/images/94a7e9a5-23d0-46b3-a68a-ffdb.jpg
4 Years Ago by Procrastinator
