Headshot- Re-Project Photo- Camera Angle?
Posted By VORESPAWN 4 Years Ago
VORESPAWN
VORESPAWN
Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)Senior Member (311 reputation)
Posts: 3, Visits: 30
Hi All,
I'm trying to re-project my image in Head-shot after making some mesh adjustments, but the figure is small/child size, the projection seems to be applied at an angle from somewhere around center of the figure focused on the figure's chin. I see there is the ability to change the lens, but is there a way to change the camera angle or position to project squarely on the figure's face?
Thank you in advance.
Last Active: 9 minutes ago
Posts: 22.7K, Visits: 35.7K
Hi...
When you use Headshot the AI should analyze the focal length of the camera which took the photo and assign a default lens value to the viewport lens. The angle and position should then be correct for that head if you require re-projecting, but you can manually adjust the lens further if you wish. Unfortunately angle and positioning are not adjustable for re-projection.
I would advise checking through the tutorials of 3DTest on the page below. These offer solutions for almost any issue you may encounter using Headshot and should help for the problems you are having.
https://www.youtube.com/playlist?list=PLNV5zSFadPdkNiTlsZI45HlCkrBGbaRXh
