Cannot make sub-props in 3DXchange 7.61 PRO
Posted By Amper Sand 4 Years Ago
Amper Sand
Amper Sand
Posts: 731, Visits: 5.2K
If somebody can guide me here:
I bought from CGTrader an animated .fbx cart+bags+horse, and it imported out-of-the-box, absolutely no problem, in 3DXchange then exported to iClone.
However, no matter what I've tried, I was unable to create sub-props for certain elements (specifically the wheels and bags), their corresponding nodes were black (not red) but the "Make sub-prop" button was disabled.
Since I needed the cart to carry something else than bags, I've done the following trick: I've hide the bags then I've exported it to iClone as a different prop, "cart without bags". But, the most important thing, the wheels, I was unable to sub-prop them - my plan was, obviously, to make them spinning in iClone using rotate transform. As you can see it (at the beginning of the clip below), the cart is basically dragged - not that I'm deeply unhappy, but I would like to know how to do it properly and also will be a good lesson to know for future similar cases.
Thanks!
vali
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
4 Years Ago by ampertox
Last Active: 12 hours ago
Posts: 9.2K, Visits: 21.8K
Depending on how it's designed, there are many times you can't make a sub-prop out of an FBX (OBJ works better in this regard).
Without actually seeing the structure (I don't have time to watch your video, assuming you show the structure there) I would advise you to take it into Blender and then export as OBJ and see if that doesn't work a whole lot better (you can also, in Blender, take things apart to get EXACTLY what you want in that regard).
