change the path for the CC3 Template files from the default C: drive to J:/Reallusion/Template
Posted By rvwalsh 4 Years Ago
change the path for the CC3 Template files from the default C: drive...
rvwalsh
rvwalsh
Veteran Member (886 reputation)Veteran Member (886 reputation)Veteran Member (886 reputation)Veteran Member (886 reputation)Veteran Member (886 reputation)Veteran Member (886 reputation)Veteran Member (886 reputation)Veteran Member (886 reputation)Veteran Member (886 reputation)
Posts: 7, Visits: 107
I want to change the path for the CC3 Template files from the default C: drive to J:/Reallusion/Template. I can't find anything in the Preference file.
Last Active: 8 hours ago
Posts: 9.2K, Visits: 21.8K
The easiest way is to reinstall and put the path in you want.
Other than that currently the only way is to edit your registry files.  It's a PITA and there are a ton of edits to make, but it's doable (and a search on this forum will reveal the changes you have to make).
rvwalsh
rvwalsh
thank you
