Neep tip for double chin
Posted By Chase MT 4 Years Ago
Chase MT
Chase MT
Veteran Member (576 reputation)Veteran Member (576 reputation)Veteran Member (576 reputation)Veteran Member (576 reputation)Veteran Member (576 reputation)Veteran Member (576 reputation)Veteran Member (576 reputation)Veteran Member (576 reputation)Veteran Member (576 reputation)
Posts: 37, Visits: 575
Any tips on creating double chin for older characters?
Thanks.
Posts: 9.1K, Visits: 21.8K
There are all kinds of double chins -- if you have some images to share we can probably advise you better (and note there are double chin morphs in CC3).
Chase MT
Chase MT
Kelleytoons, I just can't seem to make it work.  It's either the chin is too long or the jaw is too wide.  Here is the photo.  https://forum.reallusion.com/uploads/images/260bc805-cb1b-4bc6-a2a0-16bb.jpg
4 Years Ago by Chase MT
I'm loading up CC3 as I type this (very slow -- it always has to reload every single @#$@ morph brand new on my system)   Okay, it loaded up, I spent exactly 60 seconds and got this (so you can get MUCH better if you work at it).
Remember that you may need to bake repeatedly in order to get the right exaggeration.  But, honestly, if I could get this in a minute you can get very accurate with just morphing and baking.  Oh, and I see I didn't make him old, either -- he needs that.
(I was also going to suggest that worse comes to worst you could import some Daz morphs but I don't think you need them with this):
https://forum.reallusion.com/uploads/images/73e91039-014f-49d6-806f-86c6.png
4 Years Ago by Kelleytoons
Chase MT
Chase MT
Thanks Kelleytoons.  Was that straight off headshot pro?  How did you adjust the nick/double chin?  I'll keep trying.  Thanks.
Last Active: 11 hours ago
Posts: 15.7K, Visits: 30.5K
Chase MT (3/2/2020)
In the Morphs section of the Modify panel search for "double chin" and then adjust as desired.
https://forum.reallusion.com/uploads/images/be606894-49dd-4b94-80d2-365e.png
Yeah, it was Headshot pro manipulation.  Remember to adjust the neck size, because that goes a long way towards making this character look right (he has a huge neck).  And remember to use the Bake button.
If you really get stuck more let me know and I'll try a tutorial (and perhaps see if there are any Daz morphs to help).
I played a bit  more and this is what I got. There are many morphs available. Besides "double chin", check "jowel" (sometimes spelled "jowl"), "wrinkle", etc. You have to take your time, but it will be worth it.
There is an Old Male setting for Headshot. This will give you a wrinkle normal map that you can later adjust. I toned it down a bit.
https://forum.reallusion.com/uploads/images/7bb9f53a-0b46-4f79-9037-a849.jpg
I added some post-processing within CC to the render (couple of LUTs, some blur, some desaturation) for effect. Lighting is important. In this case the photo wasn't very good (no even lighting and mouth not closed), but you still get a reasonable result.
Chase MT
Chase MT
Thank you KelleyToons and Animagic.  I'm surprised I missed the "double chin" slider.  Much appreciated for both your help.
