Faceware Realtime not working test
Posted By salem_academy 4 Years Ago
salem_academy
salem_academy
Junior Member (126 reputation)Junior Member (126 reputation)Junior Member (126 reputation)Junior Member (126 reputation)Junior Member (126 reputation)Junior Member (126 reputation)Junior Member (126 reputation)Junior Member (126 reputation)Junior Member (126 reputation)
Posts: 3, Visits: 16
After greeting all of you
The iclone  program works well
And the camera is Kinect v2 Sensor read as 1920 X 1080 ( yuy2) 30fps
And Faceware Realtime  Calibrates : yes
 and the program recognized Faceware Realtime green
and i select the model and i press preview
  But the model does not move
What is the problem if someone can help me?
Thank you very much
my computer
 Operating System: Windows 10 Pro 64-bit (10.0, Build 18363) (18362.19h1_release.190318-1202)
                 Language: English (Regional Setting: English)
      System Manufacturer: Gigabyte Technology Co., Ltd.
             System Model: X470 AORUS GAMING 7 WIFI
                     BIOS: F50 (type: UEFI)
                Processor: AMD Ryzen 7 3700X 8-Core Processor              (16 CPUs), ~3.6GHz
                   Memory: 65536MB RAM
      Available OS Memory: 65484MB RAM
                Page File: 14762MB used, 60449MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
 DirectX Database Version: Unknown
           DxDiag Version: 10.00.18362.0387 64bit Unicode
Card name: NVIDIA GeForce GTX 1080 Ti
        Manufacturer: NVIDIA
           Chip type: GeForce GTX 1080 Ti
            DAC type: Integrated RAMDAC
         Device Type: Full Device (POST)
          Device Key: Enum\PCI\VEN_10DE&DEV_1B06&SUBSYS_374D1458&REV_A1
       Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
 Device Problem Code: No Problem
 Driver Problem Code: Unknown
      Display Memory: 43868 MB
    Dedicated Memory: 11127 MB
       Shared Memory: 32741 MB
        Current Mode: 1920 x 1080 (32 bit) (60Hz)
         HDR Support: Not Supported
    Display Topology: Internal
 Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
     Color Primaries: Red(0.649414,0.337891), Green(0.289063,0.609375), Blue(0.145508,0.070313), White Point(0.312500,0.329102)
   Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
        Monitor Name: Generic PnP Monitor
       Monitor Model: S23A700
          Monitor Id: SAM085E
         Native Mode: 1920 x 1080(p) (60.000Hz)
         Output Type: DVI
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
      Advanced Color: Not Supported
Last Active: 53 minutes ago
Posts: 9.2K, Visits: 21.8K
I don't think the Kinect can work as a webcam -- use a real webcam instead.
salem_academy
salem_academy
Thank you for help
But I watched some videos on YouTube
If you are sure, please advise me of the required type and specifications
It uses it as a private web camera and its quality is high
It works for me as a camera as in the link
Also, I tried using a mobile phone with a program
And I use it to track movement and it works well on the same program
Only this part is in tracking facial movement
And you very much
4 Years Ago by salem_academy
Here are a few webcams that will work:
Logitech 1080p, 920s, 922, Brio.
For further specifics on what should work I would advise you to put in a trouble ticket direct to Reallusion.
salem_academy
salem_academy
thanks i will do
pupkin96vasya
pupkin96vasya
New Member (36 reputation)New Member (36 reputation)New Member (36 reputation)New Member (36 reputation)New Member (36 reputation)New Member (36 reputation)New Member (36 reputation)New Member (36 reputation)New Member (36 reputation)
Posts: 9, Visits: 72
Hello why does device mocap not work with your plugin at the same time ?
