Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
I have (probably) not been able to use CC 3 avatars since the last CC 3 version Send more to Iclone 7 with the command "Send to Iclone" if I have reduced the polydress in CC 3. The old CC 3 that I have already created with the previous CC 3 versions and sent to Icloen via "Send to Iclone" also do not work anymore. Strangely enough, GameBase does. CC 3 avatars and CC 3 with the original clothing (without reduction)
Greets from Germany Postfrosch
facr73
facr73
Visits: 21.9K
That also happens to me.
rosuckmedia
rosuckmedia
Last Active: 5 hours ago
Posts: 3.1K,
Visits: 4.7K
Same for me, rosuckmedia
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Nobody else uses the command "Send to Iclone" from CC 3 (also with clothing reduced in CC 3) - this no longer works (probably since the last but one update) - or it works for everyone else What still works is "Send to Iclone" with non-poly reduced clothing
Posts: 15.7K,
Visits: 30.5K
I usually save the iAvatar first, which always works. I don't normally use "Send to iClone". But you are right, "Send to iClone" does not work with poly-reduced clothing.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hello RL, I have now received confirmation from several users in both the English and the German forum that CC 3 Avater with reduced clothing in CC 3 can not be brought to IClone with the "Send to Iclone" command. There is definitely a bug here Kind regards from Germany Postfrosch
Postfrosch (2/23/2020)
Hello RL, I have now received confirmation from several users in both the English and the German forum that CC 3 Avater with reduced clothing in CC 3 can not be brought to IClone with the "Send to Iclone" command. There is definitely a bug here Kind regards from Germany Postfrosch Hi Postfrosch Your feedback has been passed to the CC team. Once more is known about a fix I'll update again.
UPDATE: The CC team have confirmed the issue and plan to fix it in the 3.3 update.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hi9 Peter, Thanks for the Answer Greets Postfrosch
