Avatar Add Attribute possible?
Posted By fabiogoncalves 4 Years Ago
fabiogoncalves
fabiogoncalves
Senior Member (422 reputation)Senior Member (422 reputation)Senior Member (422 reputation)Senior Member (422 reputation)Senior Member (422 reputation)Senior Member (422 reputation)Senior Member (422 reputation)Senior Member (422 reputation)Senior Member (422 reputation)
Posts: 8, Visits: 116
Is there a way to add attributes to an avatar so they can be accessed later on when the user reloads that avatar?
If not how would one go about saving avatar specific data?
Thanks in advance
Posts: 5.7K, Visits: 26.4K
What exactly do you mean by "attributes"?
fabiogoncalves
fabiogoncalves
I mean I would like to save data (like key,values) with the avatar.
Just like the avatar has associated morphs if that makes sense.
Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)
Posts: 5.0K, Visits: 15.9K
You do it my saving a range in Collect Clip data track on a timeline.
To create a range, left mouse click on Collect Clip and drag to the left or right and release.
Then do right mouse click on the resulted blue bar and use Add MotionPlus to Library (or other options).
This would create a separate file which could be applied to freshly loaded avatar.
fabiogoncalves
fabiogoncalves
Sorry, I didn't explain myself properly.
I meant achieving the above through python, saving variable information via python
Ah sorry, according to RL Python WIKI saving in iClone formats are currently unsupported. Maybe in the future.
elMartino
elMartino
Senior Member (312 reputation)Senior Member (312 reputation)Senior Member (312 reputation)Senior Member (312 reputation)Senior Member (312 reputation)Senior Member (312 reputation)Senior Member (312 reputation)Senior Member (312 reputation)Senior Member (312 reputation)
Posts: 9, Visits: 701
You can write files with python though. If you just want to write some ini data into files it can simply done with:
path = 'E:\\path1\\path2\\path3\\'
f= open(path + "avatar.ini", "w")
f.write("avatar:key:value")
f.close()
You can also use some packages to help with the structure like csv etc. Your scripts can load/parse this information so you have it available automatically.
If you don't want to use files you could abuse the registry too.
fabiogoncalves
fabiogoncalves
Thank you.
