Character Creator 3 v3.21 viewport problem
Posted By Choub 4 Years Ago
Choub
Choub
Junior Member (163 reputation)Junior Member (163 reputation)Junior Member (163 reputation)Junior Member (163 reputation)Junior Member (163 reputation)Junior Member (163 reputation)Junior Member (163 reputation)Junior Member (163 reputation)Junior Member (163 reputation)
Posts: 2, Visits: 53
Hello everyone,
I've recently updated my Character Creator 3 (Pipeline version) to the 3.21 version and now I have some issues with it.
It was working fine untill I updated it.
Now when I open a default project, I end up with a textureless model. (it's just a visual problem, the textures are here in the material panel)
https://forum.reallusion.com/uploads/images/51ad93e6-0480-4615-a0b3-3c33.png
I tried to open the sample projects and my own projects and I have the same problem.
I also tried to mess up with the settings and even re-install CC3 and nothing worked.
I have IClone 7 installed to, and it's working fine. No visual problems.
My config is : IntelCore I7-6700K, 48Go ram, GTX 1060 6GB.
And my drivers are up-to-date
I hope you can help me.
Thanks
Posts: 5.7K, Visits: 26.4K
You have the Realtime render options set to "Minimal" set them to "High" for everything to display.
https://forum.reallusion.com/uploads/images/40f6625b-620c-4a09-9f09-163d.png
Choub
Choub
Hi,
Thanks for you reply.
I think I know where the issue was !
I tried to set the render settings to "High" but it did nothing in the viewport.
So I oppened the Settings panel and I noticed that the "Max texture size" was still in "1x1" even though I switched to "High" mode.
And I was, by default, in "Minimal", with no way to change the "Max texture size" (the setting is grayed out).
Going in "Medium" or "High" I can now set the "Max texture size" to 2048x2048 in the Settings panel and everything is working fine.
https://forum.reallusion.com/uploads/images/cb4b1739-5a91-40f2-88b5-542d.png
So I believe that the update did put the "Max texture size" to "1x1" by default on all render levels.
Anyway, problem solved. Thanks.
