Iclone can't connect to faceware realtime
Posted By marietto2008 4 Years Ago
marietto2008
marietto2008
Veteran Member (518 reputation)Veteran Member (518 reputation)Veteran Member (518 reputation)Veteran Member (518 reputation)Veteran Member (518 reputation)Veteran Member (518 reputation)Veteran Member (518 reputation)Veteran Member (518 reputation)Veteran Member (518 reputation)
Posts: 19, Visits: 113
Hello,
I just installed the trial version of the faceware realtime for iclone and also the motion live plugin for iclone. The problem is that I can't connect faceware to Iclone.
In the motion live window I tried to connect to Faceware Realtime and also to FacewareLive,but both haven't worked. They just tell me failed and the preview + record button remains disabled. Instead of the phisycal webcam I'm using a virtual cam,called "manycam". I have placed a video inside the manycam window and it has been loaded also inside the faceware realtime for iclone. When the video plays,faceware realtime tracks the head movements correctly,but as I said,iclone can't connect to faceware. I suspect that the problem is not a connection problem from iclone to faceware because I see that near the faceware live and faceware realtime the item actors is 0,instead,according to some tutorials it should be 1. Let me know where is the error. And check this image : https://drive.google.com/file/d/1J11_2uQrcdgz0B5g7AC2LUBLRAZNGh_d/view ; maybe you can understand better. Thanks.
4 Years Ago by marietto2008
Posts: 9.1K, Visits: 21.8K
Offhand the only thing I can think of is the software versions of things might not coincide (IOW, perhaps the trial version hasn't been recompiled to be compatible with the release versions of everything else).
Don't really know what else to tell you except if there is something I can demo for you that would give you what you need to know before buying I'd be glad to help.
Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)
Posts: 5.0K, Visits: 15.9K
You have to activate Faceware Realtime by actually clicking on a green circle so is becomes solid (which I see you did not).
https://forum.reallusion.com/uploads/images/11006fed-cb06-4a3c-ab9d-6ab1.jpg
marietto2008
marietto2008
I need to make it work. I can't buy the licensed version before to be sure that it works in my situation. Even because it costs more than $1000. What do u suggest me to do ? To contact directly Reallusion ?
charly Rama
charly Rama
Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)Distinguished Member (7.5K reputation)
Last Active: 11 minutes ago
Posts: 1.9K, Visits: 16.8K
I check this forum everyday so I think RL team check this also and see your message Smile, indeed, contacting RL is the best thing to do
marietto2008
marietto2008
It does not work. check here...
https://drive.google.com/open?id=1cb2q3Jz5uV1B76L2VnYKksY6ryDtvBTD
It seems you are making the same mistake. In a video you have selected the Realtime Faceware row, but you never clicked the green circle I pointed you to.
That is the only way to activate and connect. What happened if you do that? What error comes up if any?
4 Years Ago by 4u2ges
marietto2008 (1/22/2020)
It would not hurt to put in a trouble ticket for this.
However, it WILL work in the situation as you describe you are trying, as I've done it a lot.  It's not as good as Live Face (with the iPhone) but it does have the advantage of working with video through the webcam emulation.
marietto2008
marietto2008
it can happens to everyone to be the perfect idiot Smile. I have clicked on the Faceware Realtime green circle and it worked. thanks.
marcelj29
marcelj29
Veteran Member (658 reputation)Veteran Member (658 reputation)Veteran Member (658 reputation)Veteran Member (658 reputation)Veteran Member (658 reputation)Veteran Member (658 reputation)Veteran Member (658 reputation)Veteran Member (658 reputation)Veteran Member (658 reputation)
Posts: 14, Visits: 402
I get the failed to connect to Faceware live and faceware realtime when I attempted to click the button.
Windows 10
ASUS X570-plus (WI FI) motherboard
G. Skill DDR4 16GBx2
G. Skil DDR4 16GBx2
XPG SX8200 PRO SDD 2TB (M2.2280 PCIe Gen3X4 SSD)
AMD Ryzen 5 3rd Gen Processor
AMD Radeon XFX RX 5700XT 8GB Grapics card
