smartdaz9682
smartdaz9682
Visits: 33
Hello. I've been messing around with CC and I''m trying to import assets for The Sims 4 (Example hair) for use with my CC models. Is there any way to do it successfully?
I tried a tutorial that involved PMD Editor, The Sims Studio and Blender but unfortunately it did not import the final FBX final I created and the same happened with any asset I tried.
If anyone has a way or a tutorial that would be awesome as the vast amount of Sims assets out there would make it a great way to add content to our scenes.
thanks
Last Active: Today @ 1:40 AM
Posts: 15.7K,
Visits: 30.5K
If the assets are in OBJ or FBX format you should be able to import those in CC via Create => Accessory. You can the change it to other forms (Hair, Cloth) as far as I know.
5 Years Ago by
Last Active: 17 minutes ago
Visits: 60.5K
You need to use the "Accessory" in the Create menu to import OBJ or FBX props. If you have CC3 Pipeline, you can then transfer skin weights. If you have CC3 for iClone, it can only be an accessory.
