mckenlynn1
mckenlynn1
Visits: 3
Why is my custom Blender FBX not recognized as a 'Character' in iClone? I need it to be a 'Character' so I can use it for Face Live plugin.
It's my first week using iClone. I've imported an FBX that I made in Blender, into iClone. It seems to be recognized as a 'Prop'. I need it to be recognized as a 'Character' so that I can use it with Face Live plugin. I'm able to edit it in 3DXChange but I see no option to convert it into a 'Character'. Also if I try to Import the FBX into "Character Creator", it says I need an FBXKey... what?
Thanks.
Posts: 9.1K,
Visits: 21.7K
You would need to import it into 3DX and do a "convert to non-standard" as a very first step. You will also need the appropriate morphs/bones in order to get facial expressions to work (there is a lot about this in the 3DX manual). Once that's done you can export as an avatar into iClone.
Posts: 22.6K,
Visits: 35.6K
Hi... Is your Blender character rigged? If it isn't then it will only become a static prop when sent to iClone. If your character is rigged then take a look at the tutorial below. It's an oldie but should still help you with the process of converting to a non-standard character for iClone. "Importing Blender Characters to iClone" https://youtu.be/Zrc1bQhUB_YNote: You can't import the character into Character Creator 3. You will need to convert it with 3DXchange 7.
