Makumba666
Makumba666
Visits: 930
Hi all, I import daz hairs in CC and they look great: Then I add the hairs to content library, create new figure, add recently saved hairs and I get this: As you clearly can see hairs are screwed. Is there any way to prevent this?
5 Years Ago by
Makumba666
Last Active: 12 hours ago
If you mean the ends of the wisps as they hang down over the shoulders -- this is a weighting issue and you really should be using physics maps on those anyway (assuming you are going to animate her). Learn about creating those maps and that should solve that problem. (And if you tell me exactly what Daz hair that is I might be able to help you with the maps).
5 Years Ago by
Makumba666
Makumba666
Visits: 930
UPDATE: I carried out small experiment - used polygon reduction on the model before I added it to library. All the same. It seems something terrible happens when CC saves content to library. I never had problem with another type of content, but hairs are definitely screwed. It may not matter if you are creating some average looking stuff, but for photo-realistic game it is unacceptable.
Makumba666
Makumba666
Visits: 930
Kelleytoons, No I mean broken line. Look near right eye.
No, that's probably just the hair going through the head -- again, weight maps would solve. Tell me the hair and let me look at it.
Makumba666
Makumba666
Visits: 930
Kelleytoons, I doubt it is weight map problem. The same broken line again, this time back side: As you can see back is distorted too. Broken lines again. I tried to apply wigths, but all the same. By the way, now I checked and all imported daz hairs have broken lines. For example: Even some standard CC hairs have the same damned broken lines inside. May be CC can not properly save strip meshes or whatever it is, it is CC.
Scyra
Visits: 2.5K
Something for you to try...import the hair as an Accessory and save it to your library, then turn the Accessory into Hair with Transfer Skin Weights any time you want to use it. It's worth a try.
Makumba666
Makumba666
Visits: 930
UPDATE: Another experiment. This time I opened new document, zeroed all morph sliders and applied daz morph slider... and it works like a charm. I think you were right. Any idea how can I make hairs work correctly with other heads? P.S. One way I already know - weight painting. But is there easier way? One thing that I hate above everything in 3D is painting weights.
5 Years Ago by
Makumba666
How are you importing the hair? You should be doing it on a BASE Gen figure (just the standard one, with no character applied). Then the hair will correctly fit any and all characters (with some slight movements/fitting depending on the character). If you import Daz hair that has been applied to a character with morphs on it it will only look right on that particular character.
Makumba666
Makumba666
Visits: 930
I am usually importing it with custom morph. Probably that's the reason. I will try import it with base gen figure after dinner. Hope it will work.
