SagaStudios
SagaStudios
Visits: 310
When I attempted to install I get a CRC error. Do I have to uninstall CC3 again for a new plugin. I had to do this with the useless IRay plugin. Any ideas?
Last Active: 4 hours ago
Posts: 5.7K,
Visits: 26.4K
Redownload the Resource Pack and install it. The first download may be corrupted.
SagaStudios
SagaStudios
Visits: 310
So, I uninstalled CC3 and re-installed same error do I need to delete all the old file folders and residual left after the uninstall?
SagaStudios
SagaStudios
Visits: 310
So, I completely uninstalled CC3 (again). Deleted all old files and folders and attempted to reinstall. Same exact error regardless if I physically download CC3 and install manually or through Hub.
Edward (RL)
Edward (RL)
Visits: 4.8K
It looks like the installer was not completed download. Suggest you remove the cache first C:\Users\<User Name>\AppData\Local\Reallusion\RLDownloads\Headshot_Plugin_for_Character_Creator_Trial.exe
And then, redownload it on Reallusion Hub.
SagaStudios
SagaStudios
Visits: 310
Ok, great. I will try it out. Thanks,
SagaStudios
SagaStudios
Visits: 310
Ok so that did that didn't work. I have uninstalled everything. Deleted files in the App Data folder. For CC3 and reinstalled and still same error. I have redownloaded the resource and pack and reinstalled and that failed as well.
SagaStudios (11/28/2019) Ok so that did that didn't work. I have uninstalled everything. Deleted files in the App Data folder. For CC3 and reinstalled and still same error. I have redownloaded the resource and pack and reinstalled and that failed as well.Are you getting CRC errors when installing Character Creator 3 or just the Headshot plugin? Also what about any other Reallusion software you have installed with the Hub. Do they all give CRC errors?
SagaStudios
SagaStudios
Visits: 310
Hi Peter, I only get the CRC error when I install the HeadShot Plugin. I watched the install folder and the folder and file they site doesn't exist until you start installing the plugin. I did a search for the file and can't find that either. I installed everything manually but did updates through the Hub. Before I installed the first time it wanted to update the Resource pack. I did that through the Hub. I reinstalled update manually as well.
SagaStudios
SagaStudios
Visits: 310
Hi Peter, So, I ended up purchasing the plugin. I did manual download and install without issue. This would indicate a difference in the download package from Trial, Trial Hub and Full version.
