Hello,
If you can help I'd appreciate it, I create a couple avatars in CC3 and have used them in several projects. However, I noticed the visme is so much better, more responsive with this new plug in and wanted to up-grade my avatars. I took a photo and ran it through the plug in. You can see the results below. I tried the fast approach and it won't work. One half of the face is a different color. The Pro approach worked better but the area surrounding the eyes is darker than the original. Is there a way to correct that so that it's consistent with everything else?
The first photo is the original. The next two are with the Auto feature. The last two are with the Pro feature.
Thanks
