Posts: 5.7K,
Visits: 26.4K
@gordryd, There are 2 Resource Packs for CC3.2 and both have been updated. Have you installed the new versions? They are available for download from your user account.
5 Years Ago by
blackhawk (11/28/2019)
I have been unable to run GoZ in CC3.2. I have attempted to install GoZ in zBrush 2020 several times and have gotten the attached error message. And yes I have run zBrush as administrator each time. Has anyone else had any problems? Hi... If you are continuing to have this problem, please contact Technical Support using the link below. Thanks. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
wolfwonk (11/29/2019) I've tried multiple times to get the trial to work and I just get the splash screen then the process ends...
Uninstalled, reinstalled and nothing.
Checked driver and I have the latest, any idea guys?Can you share your system specifications including your graphics card. Thanks.
gordryd
gordryd
Visits: 7.6K
I downloaded and installed latest resource pack(s) for CC3.2 and still have all the same problems (except the "Trial" label is now gone): I loaded CC3_DH_0Male.ccAvatar and then tried to apply Skin Template> Normal> DH Shader Preset> Dark Male (actually, none of the shaders have any apparent effect on the character) When I apply the shader and uncheck "Apply Material without Shader Settings" box, the skin color doesn't change. But if you check the box the skin turns pure white. How do you apply the DH shader to affect the skin color? Applying any of the new eyes (for example, "Eyes_01") to a CC1 character will make the eyes bulge out through the eyelids (see picture). Converting to CC3 doesn't fix it, and neither does "Correct Eyeblink".
luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.4K
gordryd (12/4/2019)
I downloaded and installed latest resource pack(s) for CC3.2 and still have all the same problems (except the "Trial" label is now gone): I loaded CC3_DH_0Male.ccAvatar and then tried to apply Skin Template> Normal> DH Shader Preset> Dark Male (actually, none of the shaders have any apparent effect on the character) When I apply the shader and uncheck "Apply Material without Shader Settings" box, the skin color doesn't change. But if you check the box the skin turns pure white. How do you apply the DH shader to affect the skin color? Applying any of the new eyes (for example, "Eyes_01") to a CC1 character will make the eyes bulge out through the eyelids (see picture). Converting to CC3 doesn't fix it, and neither does "Correct Eyeblink". CC1 character need to use the eyes under this path (\Template\Character Creator 3 Template\Eye\CC1 Base) If you want to use CC3 eyes, please use the adjust bone to fix the pop-up issue. The new shader presets only have shader parameters so it won't affect your skin color or map.
friday2sense
friday2sense
Visits: 101
Speaking of eyes, the 3.2 template eyes appear more "natural," but they're so bloodshot and moist, they look like somebody drank until 2am and they're still crying over a lost love. I'm not finding Appearance or Materials edit options in Modify. Any thoughts about adding a "Healthy-Looking" eye package?
i7 8700K, 32GB, Win10, GeForce GTX 1070 8GB
luke (RL)
luke (RL)
Visits: 5.4K
friday2sense (12/4/2019) Speaking of eyes, the 3.2 template eyes appear more "natural," but they're so bloodshot and moist, they look like somebody drank until 2am and they're still crying over a lost love. I'm not finding Appearance or Materials edit options in Modify. Any thoughts about adding a "Healthy-Looking" eye package?
You can remove the base color blend map to get the *clean* eyes
dankdrft
dankdrft
Visits: 97
CC3 Asks for RLSysRegAgent to auth as admin, when I hit accept, CC3 crashes on export to iclone or FBX.
It hasn't asked me for a serial yet, which is what I think the auto auth is for, but this is a new issue. CC3 ran perfect with iclone for months.
dickdickdick999
dickdickdick999
Visits: 76
CC3 will NOT recognize the additional content downloaded after purchasing it.
I have contacted support, uninstalled everything and manually deleted remaining appdata directories, as well as used the registry cleaner tool they provided to me.
When I reinstall the hub, it somehow has me already signed in, and behaves as though CC3 is installed.
It will not allow me to uninstall it, or open it.
Now I am worse off than when I contacted support.
dankdrft (12/21/2019) CC3 Asks for RLSysRegAgent to auth as admin, when I hit accept, CC3 crashes on export to iclone or FBX.
When you install Character Creator 3 using the Reallusion Hub it won't ask for a serial number. The RLSysRegAgent is used to check your account for software that is registered and then it install it. Do first check that you have the latest graphics drivers installed as this should help stability, but If you continue to have problems with crashing, please contact Technical Support and let them have your dxdiag.txt. Thanks.
5 Years Ago by
