sterlingy
sterlingy
Visits: 684
For some reason, sometimes when I calibrate, the mouth tracker seems to move to the bottom of the nose. I was wondering if anyone has had this issue and how you resolved it, assuming you did? Cheers, Sterling
Stick with the flock, end up a lamb chop!
--------------------- GEAR -------------------- MSI G60 Ghost AMD 2700X 8 Core @ 4.3GHz Asus Astrix RTX 2080Ti 32GB Ram Samsung 21:9 3440x1440 Monitor Perception Neuron Mocap (2)
Reallusion Pipeline Suite 3D Studio Max Modo 901 Unreal Engine 4 Zbrush Allegorithmic Substance LIVE Adobe CC
Last Active: 11 hours ago
Posts: 5.0K,
Visits: 15.9K
In Faceware Realtime for iCone > Settings make sure to select "StaticCam_..." as oppose to "HeadCam_..." profile (that is if your camera is indeed static).
5 Years Ago by
sterlingy
sterlingy
Visits: 684
Thanks for the reply.
I'm using a headcam, so that is the setting for me, but I did try both, just in case.
I find it odd because the mouth tracker is dead on and then I hit calibrate and the tracker moves to the bottom of the nose. I also toyed with the angle of the camera on my face to see if there was some visual that was confusing the application. Didn't make a difference.
The other thing is, this doesn't happen all the time.
Posts: 5.0K,
Visits: 15.9K
I see. I do not have a *head rig* and using static camera. But as I was experimenting, whenever I switch to HeadCam profile and calibrate, sometimes mouth tracker jumps to the nose and nose tracker getting scaled down. I noticed however it is happening mostly when the distance between face and camera is over 1.5ft. Moving closer seems helping to get tracker in right spots though.
sterlingy
sterlingy
Visits: 684
4u2ges (11/7/2019) I see. I do not have a *head rig* and using static camera. But as I was experimenting, whenever I switch to HeadCam profile and calibrate, sometimes mouth tracker jumps to the nose and nose tracker getting scaled down. I noticed however it is happening mostly when the distance between face and camera is over 1.5ft. Moving closer seems helping to get tracker in right spots though.
That is what I am experiencing. My camera is about 6 inches from my face and everything lines up just as it does in the tutorial video series. What kind of camera do you use?
Posts: 15.7K,
Visits: 30.5K
I've found that I need really good lighting, so I have placed a LED bar on top of my monitor. Now I don't know if you move around with your head-cam, so in your case any lighting solution would be different.
sterlingy
sterlingy
Visits: 684
I actually have lighting on my headcam, but I have it disabled. Maybe that's what I need to try. I had attempted to calibrate in a well lit room with daylight, but the problem still happened.
I'll re-wire the lighting tomorrow and let you know if I have better results.
