Smart Ears
Smart Ears
Visits: 489
I use a Mac and have never had a problem with the 360 head creator when I take a character in composer. However, after updating to 4.1 on Mac, the 360 head creator is grayed out and I cannot access it. I thought it was because I was using a custom character head I created, but this is happening with the existing reallusion G3 characters as well. Is this somewhere else in 4.1 on Mac, or do you access this in a different way? Help!
Last Active: 10 hours ago
Hi... The 360 Head Creator button should only be unavailable when you have an incompatible character selected like a G2 characters or a morph based character. If you have tried one of the default characters such as Martha_F and the 360 Head Creator still can't be selected, then it may have be that the update was not completed successfully. In this case it would be worth uninstalling CTA4 and then reinstall the full 4.1 version. This should then allow correct functionality of the 360 Head Creator.
Smart Ears
Smart Ears
Visits: 489
Ok - thanks! I will try your suggestions
Smart Ears
Smart Ears
Visits: 489
Thanks! The 360 Head Creator works with the existing characters. So my question now is --- how do I create a 360 head from scratch for some of my characters? I also read that you can create layers in PS using the naming rules. Is there a place to see the naming rules? I've usually always used the PSD template. Finally is there a 360 PSD template?
