ponddigger
ponddigger
Visits: 101
Kalle3
Kalle3
Posts: 1.0K,
Visits: 2.1K
Hey, versuche das ! Grüße aus Germany Kalle
Wenn es nicht funktioniert, ist es noch lange nicht kaputt!
Wenn es nicht kaputt ist, reparieren wir es auch nicht.
Wenn es funktioniert, stell keinen Scheiß damit an!
ponddigger
ponddigger
Visits: 101
It did not change the sails at all. It did fix the problem I was having with the rigging, but still no realistic looking sails (I did apply the 2-sided function to all the materials). Thank you.
5 Years Ago by
ponddigger
Try this... This will open up a "Adjust Color" panel, and there you can INCREASE the BRIGHTNESS of the opacity channel, making it more opaque. The grayscale level of that channel will define a " maximum opacity," so even setting the Opacity slider to 100% will not make a "gray" value entirely opaque. The opacity slider can only decrease the level of opacity.
5 Years Ago by
ponddigger
ponddigger
Visits: 101
That worked. Thanks again to you both..
