Posts: 9.1K,
Thanks, Allen -- but would you please either let someone (me?) test this or at the very least make sure the new release is commented enough so we know when it changes? I ask because I've got my workflow defined now and if/when it changes I don't want to be surprised <g>.
@AllenLee(RL),
Thank you for the informative reply. It's great to hear you think it can (will) be fixed.
I agree with Kelleytoons' suggestion that someone be able to beta test the fix. Right now, he has a workaround which is relatively easy to perform, and it would be sad if the "fix" broke the workaround.
Why would it be sad if the workaround quit working? Because there are so many different system with different versions of windows and different drivers and different pieces of hardware, it might be difficult to have a flawless solution that works on everybody's system. That is why, a) It is important to have several normal users test it on their systems at home, and b) There still might be a need for Kelleytoons' workaround sometimes.
Hopefully the fix will be great, and will work perfectly 99% of the time (or more).
Thanks again for your great reply in this thread. Good luck with the fix.
