Render comparison iClone vs IRay
Posted By Zeronimo 5 Years Ago
Zeronimo
Zeronimo
Last Active: 16 hours ago
Posts: 478, Visits: 19.1K
left : iClone render                                                           Right : Iray Render
Quality compressor Video : 8                                          Default parameters
Quality compressor Audio : 8                                          Frame Rate : 60
Frame Rate : 60                                                              Frame size  : HD 1080p (1920x1080)
Frame size  : HD 1080p (1920x1080)                            Total Frames : 900
Render quality : High (3x3)                                             Frame itération : 200
High quality shadow                                                        Render time : 4 hours
Total number of frames : 900
Render time : 12 mn
1 - The colors are more intense rendered by iclone, but maybe if I had taken a longer iteration time in IRay I would have had a better result;
2 - The yellow colour of the skirt is different between the 2 renderings;
3 - The ground (water) and the reflection do not appear in the IRay rendering. (but this may be due to my lack of knowledge of IRay settings).
4 - it seems to me that physics does not give the same result in IRay
For my part, I find that the native rendering by iclone suits me perfectly, I might use IRay for very short sequences when I master it better.
5 Years Ago by zeronimo
Daemonspike
Daemonspike
Posts: 159, Visits: 942
I actually prefer the iClone version.
5 Years Ago by Daemonspike
Daemonspike
Daemonspike
But that was one u--y lady!
ultimativity
ultimativity
Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)Distinguished Member (3.5K reputation)
Posts: 356, Visits: 729
Both renders ran very smoothly.
Did you convert the materials to IRay before rendering in IRay?
Nathan
5 Years Ago by ultimativity
Zeronimo
Zeronimo
ultimativity (10/19/2019)
The character is cc3 type and all textures are traditional shader type.
I made no conversion to IRay material.
Last Active: 34 minutes ago
Posts: 15.7K, Visits: 30.5K
zeronimo (10/19/2019)
Iray does not render iClone water. However, you can use a reflective ground plane instead.
Did you bake the cloth physics? That would be necessary to get the same result.
5 Years Ago by animagic
Zeronimo
Zeronimo
animagic (10/19/2019)
I realized that the water wasn't there at the end of the rendering. After 4 hours, but I didn't want to do it again. But indeed in this case it would have been a good solution to use a reflective ground plane instead.
I found nowhere in the settings of Iray how to bake cloth physics.
Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)Distinguished Member (20.6K reputation)
Posts: 5.0K, Visits: 15.9K
You have to bake physics in iClone. Regular way. Enable Bake Animation in *Project", play in By Frame mode, disable Bake Animation and disable physics for hair and skirt.
On a side note, it is strongly advised to convert Traditional materials to PBR for Iray.
And a reminder: Render with 1280x720 (it would be twice as fast) and then upscale image sequence to 1920x1080 with Topaz Gigapixel AI.
Results might vary, but it does darn good job in most of the cases.
Finally, don't forget about Tonemapper, Tweak settings on single frame preview and all settings would be transparent for animation.
5 Years Ago by 4u2ges
Zeronimo
Zeronimo
4u2ges (10/20/2019)
Thank you for all this excellent advice. I will take it into account and implement it as soon as possible.
