rjj1234 (11/7/2019)
Hi Peter,
What _might_ be happening is my PSD editor is not updating the object I opened using the PSD editor button in CTA4. After I save it, in this case in Affinity Photo which opened perfectly after hitting the PSD editor button, nothing happens in CTA4. Should it switch into Composer mode automatically?
Thanks!
Robert
Hi Robert
If you have Photoshop I would try using that to see if the problem is only with Affinity.
So for example, as a test open a G3 character in CTA4, send into Composer mode and then select "Launch PSD Editor" from the left side toolbar. Now make some changes in Photoshop such as recolor an item of clothing, then choose File > Save from the Photoshop Menu Bar (not Save As). You should then find the character in CTA4 will update automatically. This works for me with Photoshop so hopefully it will for you too.
