4u2ges (10/14/2019)[hr
That might be good solution overall. But I hope it is temporary until RL comes up with permanent fix.
Time to be picky about something else now.
I should've probably created another thread but anyway...
This keeps bugging for a long time! Cloth/Shoes Confirm. With all the bells and whistles new "Confirm" has to offer in CC3, I do not like it a bit.
The core is not working as I expect it to work. Here is an example off the top of my head about shoes. This is a Low Heel Sandals form Essential pack.
1. In CC 2 applied to the base model. Tight and neat fit.
2. In CC3 applied to the base model. There is not much difference in the feet shape between CC1 and CC3 base. Why are they loose? Nothing I can do here to make them tight.
3. Brought CC1 base to iClone (from CC2), sent it to CC3, Opened "Confirm" and disabled it. Saved the shoes. Opened default project and loaded saved shoes.
This is the only way I can have those shoes fit tight in CC3. Is that normal?
On top of all, if I enable Confirm now and save them, next time I apply those shoes they would be loose again.
Shoes would also get loose if I just move "Increase Size" slider a notch up and back to 0.
I think the minimum value for "Increase Size" slider is messed up and needs fixing! Just to let you know this has been logged and the plan is to fix it in a future update. Thanks for reporting it.
